AutoCAD Plant 3D Forum
CHANGING PARTS SPECICATION
3 REPLIES 3
299 Views, 3 Replies
Why when we change parts specification in model 3D PLANT 2017, sometimes the weight is set to 0 and status set to blank ?
See attached files.
Best regards.
3 REPLIES 3
Bernd.Gerstenberger
Hi Serge,
my first suggestion is that in spec G1L-3 the weight is defined for the pipes but not in the spec G1A-3. After changing the spec in the Plant model you only see the properties of spec G1A3.
Best regards
Bernd G.
Senior Product Support Specialist
in reply to: Bernd.Gerstenberger
Thank for your answer.
The weight is defined in G1L-3 and G1A-3 specification.
Below screen printing :
[cid:image001.png@01D45A2D.CA1307E0]
[cid:image002.png@01D45A2E.52906FE0]
We have the same problem with the status field.
The status field is blank! (Post in the forum of 06/13/2018)
Best regards.
Bernd.Gerstenberger
Hi Serge,
I will send you a private message. Please, send me a small model drawing, the two specs and your DefaultConnectorsConfig.xml. So, I am able to reproduce the behavior.
Best regards
Bernd G.
Technology Administrators
AutoCAD Beta
