Dear Plant3D experts,
I have an issue with adding the ortho annotation leader position.
by default, lead as the picture below:
Both left and right, the original point is set in the bottom center. theses leaders will intersect when having many lines in view.
so, I wanna config leader style for annotation style as snapshot below. I try to edit style with set up in mulities leader style manage. However, It only works with leader as set up in Autocad and does not work when I set up in P3D. Someone can tell me what's going on?
Thank you!
Solved by jw7018. Go to Solution.
Copy/add existing annotation and mod as req'd.
One example below moving leader to "end" placing at 0,0,0
