Change Operator symbol
wbierma5QHZ8
wbierma5QHZ8
Hello Everybody,
In the catalog i created a custom plant DWG based valvebody.
Next to that i created a custom operator with as Iso Symbol Type: Operator and Iso Symbol Skey: 02SP (Which is a pneumatic operator).
When i make an isometric drawing i alwys get the manual (01SP) operator. No matter what settings i change.
Does anybody have a clue at what i'm missing?
We do not use the OperatorSpindel.
Wiebe
DVaquand
Hello
See if this topic can answer you question
https://forums.autodesk.com/t5/autocad-plant-3d-forum/control-valve-handle-isn-t-appear-on-iso-what-...
Cordialement
Dominique VAQUAND
www.dovaq.fr
Cordialement
Dominique VAQUAND
www.dovaq.fr
Cette publication vous a-t-elle été utile ? N’hésitez pas à attribuer la mention J’aime à cette publication.
Avez-vous obtenu la réponse à votre question ? Cliquez ensuite sur le bouton ACCEPTER LA SOLUTION.
wbierma5QHZ8
@DVaquand
Thank you for your fast reply.
That solutions uses the spindelskey. Whereby you add a operator to a valvetype.
This is not what i want becasue we use butterfly valves with manual and pneumatic operators.
