AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Change nozzle thickness on converted equipment
5 REPLIES 5
487 Views, 5 Replies
Hello everybody,
I have a converted equipment in Plant 3D and I've added a nozzle using the NozzleGrip icon. I want to change the nozzle thickness, because the nozzle on the equipment is a custom nozzle.
I tried to change the thickness of the specific nozzle in the 'Common Nozzle Catalog' and used specific nozzle this on my converted equipment, but on the isometric the length of the bolts stays the same. I've added some screenshots of the Common Nozzle Catalog.
Does anybody knows another method to change the thickness of the nozzle of a converted equipment?
Many thanks,
Matthew
5 REPLIES 5
h_eger
Dear @Anonymous,
I can not understand this problem with the bolt lengths.
It works very well with me.
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
in reply to: h_eger
Hi H.Eger,
Thank you for your reply.
The equipment you're using is a parametric equipment from Plant 3D. If you have an equipment dwg which is converted for Plant 3D usage, the bolt length won't change when you select a custom nozzle.
I've read other forums yesterday and it seems that this problem is known by Autodesk since 2013.
https://forums.autodesk.com/t5/autocad-plant-3d-forum/bolt-length-correct-on-parametric-but-not-cust...
https://forums.autodesk.com/t5/autocad-plant-3d-forum/wrong-bolt-length-when-connecting-to-flanged-n...
https://forums.autodesk.com/t5/autocad-plant-3d-forum/bolt-length-on-equipment-flanged-nozzle-issue/...
Matthew
DC_42
Does anyone have a work around for this issue? It's still the same in Plant 2024
h_eger
We don't have these problems because we use the external tool from Auxalia with the Plant Express Tools  and their bolt length calculation.
Have you already reported this problem to Autodesk Plant 3D Support?
Hartmut Eger
Senior Engineer
XING | LinkedIn
AndyDavisCadline
in reply to: DC_42
For what it's worth, it's still not been fixed in 2025 either.
The flange thickness is not being written to the port records for the nozzles.
There is a workaround that will calculate bolt lengths but only for nozzle 1.
If you update the property settings on the Equipment class through project setup to make the Flange Thickness writeable,  you can enter a value for your custom equipment.  The first time you make a connection to nozzle 1, this value will be ignored. However, if you use the substitute grip to change the boltset on the connection, the value will be read and the bolt length will be calculated correctly.
If your custom equipment has more than 1 flanged nozzle or it's not nozzle 1, you're out of luck.
Andy
Andy Davis
Industry Specialist
Cadline Ltd.
