Message 1 of 8
09:21 AM
I have a standard gasket I use throughout the plant. However, we use a special gasket for glass lined vessels. I have created the gasket, added it to the spec, but whenever I put a flange connection in and try to change the item, it just says 'Flanged Connection.' How do I select which gasket to put in?
For instance, if I want to put in a reducer and put one in, it will automatically put in a 6"x4" reducer, but then I can select change part and put in a 6"x3" reducer. I want to be able to do this with the gaskets.
