Change default location of Nozzle Catalogue
ljboxer1983
ljboxer1983
We work on multiple P3D projects and we are currently working for a company in the water industry, we have had to customise the nozzles catalogue,
But we have noticed that the P3D project locates the nozzles catalogue from C:\AutoCAD Plant 3D 2018 Content\CPak Common,
Can we change the default location to our server, so all our operators are using the same catalogue?
Artem_Marinin
Hello @ljboxer1983,
You can change content folder path. Read about it here.
But be aware it will change not only Nozzle Catalaogue path, it will change path of whole AutoCAD ® Plant 3D Content folder.
Best Regards,
Artem Marinin
Dan.Scales
Hi @ljboxer1983,
It is, as @Artem_Marinin says, possible to change the location of the content folder to a network path. Unfortunately it is not possible to modify the location of a single catalog such as the Nozzle Catalog to a different folder.
Dan
Dan Scales
