Centered flow arrows on line segments
Is there anyway to adjust settings so that flow arrows are centered on drawn line segments rather than on the ends? I am currently using PID PIP- Primary Line Segment.
Please see example below.
Scott
cadPNYBN
This doesn't answer your question but industry standard for decades has been to locate flow arrows on P&IDs at all direction changes. Curious why you want to place them on center.
quentin.contreras
Autodesk Support
Autodesk Support
@Anonymous unfortunately the AutoCAD P&ID process only allows for flow arrows to be placed where line segments change direction. This is normal practice in P&ID diagrams.
You can choose not have the flow arrows automatically placed by changing this in the project setup. Then you could create an arrow block to place manually.
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Quentin Contreras
Technical Support Specialist
