cannot connect parts - Butterfly valve
Message 1 of 16
Hi, I'm trying to insert butterfly valve (CS150), Lug, RF, 150 on the pipe but it give error cannot connect parts and the water droplets appear. How can i solve this? thanks
Replies (15)
Message 2 of 16
skintsubby
Hi @Anonymous
You need to give us more information than that.. What does the error say? Post a screenshot if possible.
Mark
Message 3 of 16
Hi @skintsubby
Thanks for your reply.
please find attached screenshot, thanks
kindly note that i've tried the following and didn't work:
- changing connection to be flanged.
- checking ports dimension
- allowing imperial to metric connection
Message 4 of 16
Any one can help?
Message 5 of 16
Tomislav.Golubovic
The pipe is also CS150 Spec?
Message 6 of 16
Ganesh.balasubramani2316
Hi @Anonymous ,
Can you please share us the spec, so that we can check from our side. Thanks. 🙂
Message 7 of 16
yes, both the valve and pipe are CS150
Message 8 of 16
Message 9 of 16
Is there a solution?
Message 10 of 16
what is the problem here? How can i solve this to get the isometric? no reply from autodesk too.
Message 11 of 16
Tomislav.Golubovic
It works on the OOTB CS150 Spec
Message 12 of 16
@Tomislav.Golubovic  what's the difference? it's the same specs if i am creating a new component
Message 13 of 16
Tomislav.Golubovic
So you've edited the CS150 spec with a new valve? Can you post it here so we can look at it and then troubleshoot it.
Message 14 of 16
I am working with pneumatic control valve manufacturing company and I did not face this problem in designing.
Message 15 of 16
rajendra.prajapat
To connect this valve spec should have flange ,bolt set and gasket for RF facing and pressure class 150.
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Message 16 of 16
Do you know? why the kobo frozen issue arrives in your kobo device. It happens because sometimes, your kobo device is not capable of handling the things in the way it's intended to and gets stuck down. That is why, your kobo device gets stuck and it does not allow you to read books on it.
