Can`t find symbol for specified part Plant 3D 2024
juancarlosmv1980
juancarlosmv1980
Until a few days ago I have been creating all types of pipe fittings without any incident to create my own specifications, but I don't know what happened that stopped working correctly and I can no longer create any type of part.
I first make the block of the part (in this case I am creating Bushing), then I apply plantpartconvert assigning the two respective arrows, then I go to the specific one and make the part as if it were a concentric reducer, finally assigning the block that I have created . previously. I update the specifications list, choose the specification in which the Bushing is and proceed to insert the created part, in fact, you can see the icon of the part in Tool Palettes, but when I click on it to insert it in the drawing it is when I get the following message on the command line;
"Can`t find symbol for specified part."
What could have happened to make it stop working for me? I have tried creating the parts in different catalogs and in different specifications and the same thing still happens to me.
I greatly appreciate your help.
Greetings.
DVaquand
Hello @juancarlosmv1980
See topic
https://www.autodesk.fr/support/technical/article/caas/sfdcarticles/sfdcarticles/FRA/Can-t-find-symb...
Cordialement
Dominique VAQUAND
www.dovaq.fr
Cette publication vous a-t-elle été utile ? N’hésitez pas à attribuer la mention J’aime à cette publication.
Avez-vous obtenu la réponse à votre question ? Cliquez ensuite sur le bouton ACCEPTER LA SOLUTION.
juancarlosmv1980
Hello @DVaquand , Thank you for your response but I have tried and it still doesn't solve the problem.
I find it strange that I can see the icon in the tool palette but it won't let me insert the part.
Does anyone have any more ideas as to why this might be?
DVaquand
try
1 - Empty the Plant 3D cache by launching "PnPLocalDataCachePurger.exe", file placed in the folder "C:\Program Files\Autodesk\AutoCAD 202x\PLNT3D"
2 - Run the "AuditProject" command from the data manager without opening a drawing
3 - Open the 3D file and launch the “Control” command
== French ==
Essayez
1 - Videz la mémoire cache de Plant 3D en lançant "PnPLocalDataCachePurger.exe", fichier placé dans le dossier "C:\Program Files\Autodesk\AutoCAD 202x\PLNT3D"
2 - Lancez la commande "AuditProject" depuis le gestionnaire de données et ce sans ouvrir de dessin
3 - Ouvrez le fichier 3D et lancez la commande "Controle"
Cordialement
Dominique VAQUAND
www.dovaq.fr
juancarlosmv1980
Hi @DVaquand ,
In step 3, I understand that I open the 3D drawing and then write "control" in the command line, but I only get the command option "controlvalve", I think that's not it, right?
DVaquand
3 - Open the 3D file and launch the “Audit” command
Otherwise
Open the catalog and see if the custom component block is recognized.
Check in the specification editor if the catalog search path is correctly configured.
In the "Cpack" folder of your catalog you should have a "DIN Pipes and Fittings Catalog" folder a "DWG" folder which contains all the custom blocks.
Please note, in this "DWG" folder, each DWG file is in fact the family code of your personalized parts. Inside each file (family), the blocks (custom part) whose name corresponds to that defined, diameter by diameter, in the catalog are stored.
== French ==
Ouvrez le catalogue et regardez si le bloc des composants personnalisés est bien reconnu.
Regardez dans l'éditeur de spécification si le chemin de recherche des catalogues est bien paramétré.
Dans le dossier "Cpack" de votre catalogue, vous devez avoir un dossier "DIN Pipes and Fittings Catalog" un dossier "DWG" qui contient tous les blocs personnalisés.
Attention, dans ce dossier "DWG", chaque fichier DWG est en fait le code famille de vos pièces personnalisées. A l'intérieur de chaque fichier (famille) sont mémorisés les blocs (pièce personnalisée) dont le nom correspond à celui défini, diamètre par diamètre, dans le catalogue.
Cordialement
Dominique VAQUAND
www.dovaq.fr
juancarlosmv1980
Hello @DVaquand, I have checked, everything was as it should be but it still does not work.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
