A similar question has been asked in this forum but I wanted to ask again because my scenario is a little different.
The material changed for skid piping. Therefore I created new spec for the skid. I would select the new spec in the properties window for a pipe etc. Worked fine for a while. All of a sudden it stops working. I change the spec and it jumps back to the origional spec. Funny thing is the long description changed and remained for the new spec. I then have to go into the tag field and change the spec there and then change it in the spec field for it to stay on the spec I selected.
Why did it stop working all of a sudden?
Also when I change to spec in the tag window most of the tag fields change to "?".
Any ideas why this happens.
Thanks!
