AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Can't Change Spec in Properties
1 REPLY 1
378 Views, 1 Reply
A similar question has been asked in this forum but I wanted to ask again because my scenario is a little different.
The material changed for skid piping. Therefore I created new spec for the skid. I would select the new spec in the properties window for a pipe etc. Worked fine for a while. All of a sudden it stops working. I change the spec and it jumps back to the origional spec. Funny thing is the long description changed and remained for the new spec. I then have to go into the tag field and change the spec there and then change it in the spec field for it to stay on the spec I selected.
Why did it stop working all of a sudden?
Also when I change to spec in the tag window most of the tag fields change to "?".
Any ideas why this happens.
Thanks!
1 REPLY 1
h_eger
Dear @Anonymous,
ever sync your project to your changes?
With:
PLANTREFRESHACQPROPERTY
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
Technology Administrators
AutoCAD Beta
