Can't assign tag line number
Hello there.
I'm having some serious trouble assigning new line numbers in my current project. I've already tried some suggestions I saw from similar posts, like Audit Project or assigning tag on my new line while routing new pipe, but they have no effect. One suggestion I saw involves SQL editing and it was only recommended for advanced users. Is there any way to fix such an issue?
Dan.Scales
Hi @Anonymous,
What happens when you try to assign a line number?
What is the SQL editing solution that you mention?
Dan
Dan Scales
Dear Dan,
The problem is when we try to assign a specific line number to a pipe.
We were surprised to see that when we tried to assign the line number "E1HTD10-BR011" the line number tag switched automatically to "unassigned". The problem disappears when we assigned any other line number (such as E1HTD10BR011 or E1HTD10-BR01312).
We attach here in the Project setup file and the drawing file.
The SQL editing solution was mentioned in simmilar post (https://knowledge.autodesk.com/support/autocad-plant-3d/troubleshooting/caas/sfdcarticles/sfdcarticl...)
Best Regards
K.Varlas
Dan.Scales
Hi @Anonymous,
Please do the following:
  • Close all project drawings
  • Right-click the project in Project Manager and select Audit Project
Once the audit is complete the E1HTD10-BR011 line number can be assigned.
Dan
Dan Scales
Thanks had same issue, trick is to close all the drawings(like you mention) else the audit does not work.
