Cable Ladder in Plant 3D
Is there any way to route/draw cable tray in Auto Cad Plant 3D 2017 without using MEP/Revit
h_eger
Hi @Anonymous,
No!
You can sometimes search in Google there were some users who also programmed an app.
But I do not know the current state.
Why not MEP?
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
maxpiper
This app will enable you to draw cable tray in Plant 3D 2017.
http://www.max-d.ca/maxdCableTray.aspx
cadwomen
Hy
so did you look there ??
https://apps.autodesk.com/All/en/List/Search?isAppSearch=True&searchboxstore=All&facet=&collection=&...
cu cw
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
blorich
Using autodesk exchange store and typing in "cable" in the search will give you a big result.
https://apps.autodesk.com/PLNT3D/en/Detail/Index?id=6712522292506674561&appLang=en&os=Win64
The CADGROUP has a great spec driven one if that interests you.
