Bug in AutoCAD Plant 3D 2022 to print items with end connection on P&IDs using PDF format through the Batch Plot tool
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello everybody.
The bug is presenting when I try to print my P&IDs collection through batch plot tool in PDF from my AutoCAD Plant 3D 2022. I have some items that are configured with end connection option. I hope that some one knows a solution, because I don't want to waste the batch plot options, due to saving time.
I show you the element in the next image, which is a house.
When I print my P&ID in a normal way, the PDF is perfect, I show you in the next image the result.
But the issue is when I use the batch plot tool because the end connection of my item disappears. I show you the result after using the batch plot tool in the next image.
I use the same configuration to print in the normal way and the batch plot, because I use a printer file, a plot style table, and a page setup file. The next image shows my Page Setup configuration.
I show you the Publish configuration in the Batch Plot tool.
I am using AutoCAD Plant 3D 2022 with the last patch and hotfixes.
