Bolt Types and when to use them?
I have been looking for a good resource to explain the different types of bolts in the ASME P3D catalog and when to use them.
Stud Bolt seems pretty straight forward to me - used in most industrial applications to fasten a flanged item to another flanged item, also used to sandwich wafer items between two flanges or when the valve has lugs that aren't tapped.
Lug Bolt seems simple enough - to me you use this bolt when you have a lugged valve when the bolts thread into a tapped hole. Now I am not sure if I use it when I have a pass through lugged valve(wafer) that requires a nut on the other end.
Machine Bolt getting more confusing - I am not sure what the difference this is and where to use it instead of the lug bolt. Can someone help me out here?
Machine Lug Bolt really confused now - I have no idea how this is different from a machine bolt or a lug bolt and where I should use this type of bolt and with what end connections.
Below are the common types of connections I am used to. For conversation sake lets number them 1-4 starting with 1 on the left and 4 on the right.
I would typically use:
Machine bolt for 1
Stud Bolt for 2
Lug bolt for 3
Will plant 3d allow a stud bolt for number 4?
So where is machine lug bolt used?
