Bolt Set Selection and Length Calculation
Having some trouble with assigning bolt sets to different connections. In my spec I want all flange type joints to use machine bolts and all wafer type joints use stud bolts. Is there a way to automate this? The other problem i seem to be getting is that if I set the bolt part priority to machine bolts and then manually change them to stub bolts after placing a wafer part in the model the length calculation is wrong. The length calculation seems to use the bolt which has the top part priority and isn't done individually. So i can change the bolt from a machine to a stub but the length is too short as the calculation is taken from the machine bolt set.
The images attached show the difference between a flanged joint when a machine bolt is set to top priority and the other when a stub bolt is set to top priority. The correct calculation should show - Machine Bolt = M24x115LG and Stub Bolt = M24x150LG. How do i get both calculations to work separately?
Running on AutoCAD Plant 2022
