Hi Everyone,
Bolt Length is same with Flange-Flange &Flange-Butterfly Valve-Flange connection in isometric drawing.
The Valve is wafer type.
With Flange-Butterfly Valve-Flange connection , using four bolt for 2" nominal size and it's correct.
The problem is , not add valve length and it is being same length with Flange -Flange connection as you see below.
What's the matter and how to solve this problem?
Thank you in advance for your help.
Hi @jabowabo,
Thanks for your interest .
we are two friends working on same project. When we drawing a piping with a another pc ,same project, same spec then the bolt length is corect. When i drawing on my computer same preject ,same spec the bolt length is wrong.
I drawing the pipe line with another pc but creating isometric drawing with my pc then bolt legth correct.If drawing on my pc then wrong.
Hi @lokman.aktas,
As the issue only occurs on your machine, you should check that the service pack levels are identical to you colleagues machine.
Also try clearing the local data cache and perhaps consider resetting Plant 3D to defaults.
Dan
Hi @lokman.aktas,
I just wanted to follow up here to see if any of the suggestions helped?
Dan
