Hi Everyone;
I had share a problem with bolt length in my project you can see in this link.
I just aware that when I drawing a pipe line with an another pc in my office ,in same project and using same spec, the bolt length is corect. When i drawing on my computer, in same project and using same spec then the bolt length is wrong. Also I drawing the pipe line with another pc but creating isometric drawing with my pc then bolt legth correct. If drawing on my pc then wrong.
If use second pc Bolt Legth wrong for Flange-BFV-Flange Connection. While caunt bolt length don't caunt Valve Length and showing as Flange-Flange connection.
I hope someone can help.
Thank you in advance for your help.
Is the project located on a server?
What does the flange thickness read for the BF valve in each model on each PC?
Hi @jabowabo,
It's a wafer type butterfly valve. I create a 3D Block later convert to Plant3D Part then create a catalog and i chose the block being a referance to catolog.Only I enter Size ,OD & Pressure Class.
How i have to control flange thickness of BFV. I did not enter any information about that to catalog.
Thanks.
"Also I drawing the pipe line with another pc but creating isometric drawing with my pc then bolt legth correct. If drawing on my pc then wrong."
This suggests that your problem is with the properties of the components inserted into 3D. Use PC #1 to draw your flange-valve-flage components, then use PC #2 to do the same thing (in the same .dwg). Then select both valves (the one drawn by PC #1 and the one drawn by PC #2) and use the Properties palette to see what the differences are; there should be no differences other than unimportant differences like x,y,z position. Repeat this comparison for the flanges too, and you should even compare the connectors.
Once you find the differences between the 3D components, that will give you a clue about how to solve your problem.
Also, I know you said you're using the same spec, but make sure that both PCs are using the same PLANTMODIFYSHAREDCONTENTFOLDER, just to be sure.
Also, your wafer valve's Length must be set correctly. It may be okay to have a null Flange Thickness for the wafer valve, because regardless of the valve's flange thickness, the valve's entire Length will have to be bolted across; OOTB wafer butterfly flanges have no Flange Thickness, FWIW.
Hi @Anonymous,
Thanks for your interest and time.
As you said i examined everything.
Because of the project located on a server spec totaly same. Also when we change anything on catalog ,we valid on both pc file. First we revise on the server later copy to both pc shared location. I couldnt solve yet.
I will examine again as you said but I don't have any hope with this way.
Thanks.
Hi @lokman.aktas,
I made some suggestions to the other forum post you made regarding this.
Could you give them a try and see if it helps?
Dan
