Hello, is there a possibility to automatically set an author for drawings in AutoCAD or Plant 3D 2018 version.
My workstations name has been set to "owner" which is an author name i do not wish to use..
regards, Jan
What properties you need change? the file? or in Plant3D properties?
in Plant3D the Author is put automatically from username (GETVAR "loginname") (readonly),
After that you create the file, is possible change selected the file in Project Manager, click rigth mouse and properties.
Roberto.
Hi, i need the Author field to be my name, not the login name (this differs from my (author) name.
I know how to change the author name, but it would be nice to set a default for this.
regards, Jan
Hello.
Were you able to figure this out? I'm asking because I'm trying to do the same thing in our titleblock. I can do this by creating a custom field (last image below), but I was curious if you or anyone knows why I couldn't use the fields highlighted in the second image attached? I tried both of these, but doesn't seem to work, but I could be doing something wrong here. Doesn't populate at all when I use these two different "author" fields, but if I do the custom field shown below, it works. I just have to set this up via "project setup". Thanks in advance.
