Autocad plant 3d linux
andrew.murray.1982
Message 1 of 11
andrew.murray.1982
I know modern versions of autocad don't work with Linux but why can't Autodesk work with something like wine or develop there own compatibly layer to allow Linux to run autocad I have to keep a VM for autocad it's the only software I can't really run on Linux. Its a shame cause they have a Mac version although only basic but surely this is not out of the realms of possiblity for autodesk
Replies (10)
Message 2 of 11
h_eger
1. Autodesk AutoCAD Plant 3D is not supported in Linux
2. The last version developed by Autodesk under Unix was AutoCAD 12!
3. AutoCAD is supported by Mac OS but does not support AutoCAD vertical products
At Autodesk it is also not in the pipeline to port further AutoCAD or vertical products in the OS systems Mac OS or Linux.
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
Message 3 of 11
Tomislav.Golubovic
Before getting into Linux, they need to work on getting AutoCAD to use more cores 🙂
Message 4 of 11
h_eger
Dear @Tomislav.Golubovic ,
AutoCAD 2022 works with multicore 😉
Hartmut Eger
Senior Engineer
XING | LinkedIn
Message 5 of 11
Tomislav.Golubovic
Please explain 🙂
Message 6 of 11
andrew.murray.1982
My point here was I realize autocad does not support Linux currently even the older versions were very buggy using wine. What I am asking and that I hope Autodesk are reading is that the wine comparability layer has come a long way and that there are now very little software that can not be run via wine and that they don't need to do a direct port to Linux but develop a way for autocad the windows version to be run via wine in Linux.
Message 7 of 11
h_eger
you are welcome
https://forums.autodesk.com/t5/autocad-forum/new-multithread-multi-core-support/td-p/8718192
Hartmut Eger
Senior Engineer
XING | LinkedIn
Message 8 of 11
Tomislav.Golubovic
OOOOOh, for 2D regen and rendering
/sarcasm
Message 9 of 11
h_eger
Multicore support is there I haven't written for anything 😂
Hartmut Eger
Senior Engineer
XING | LinkedIn
Message 10 of 11
George.Endrulat
In the past I've done a VM with windows pro (at the time windows 7) and I was able to install autocad plant 3d in it without an issue.  It's heavy, but you can get your work done.  You need to figure out all of the networking to allow the license server to work and all that but it can be done.
George
If my post offers a solution, please click "Accept as Solution"
Message 11 of 11
andrew.murray.1982
Yes this is how I am doing it just now but like you mention it can be slow running both. That's why I made the suggestion of running in wine.
