Autocad Plant 3D Instalation
I have a huge problem with AUtocad Plant 3D 2016 instalation. mWhen I run instalation I get tries message:
Does anybody can help?
Dadspackard
Hi Peter,
Is this the first time you are trying to install 2016?
I had similar issue when I tried to do a repair/reinstall of a 2015 install on my workstation. I think what casued my issue was I did some cleanup/deleting of the ACAD install folder on my local drive so I think the repair/install could not find the proper files to perform the repair/reinstall. So what I did was created a new folder on local C:\AUTODESK\ with a different name then what I had previsouly had it called. Then I copy the install package from the network to it. I then clicked setup and it went through the normal install like it was a fresh install. Hope this helps
Have great day
Tom
Tom
aka, Dadspackard, Packin31
Thank you for your reply. I tried what you wrote and I also tried tris solution: http://forums.autodesk.com/t5/installation-licensing/directx-runtime-failed-failure-is-ignored-resul... but it did not work. I do not know hot to act now.
LuckyMB
This may be a silly question, but when you installing the software do you install it from "run as administrator"?
Hello
I already installed Plant 3D 2016. I found some bugs in my windows registry so I had to reinstall my windows first and than I installed Plant without mistakes. Thanks for your reply-
we had the same, I choosed another version, I didn t play with it
