Annotation Text Height/Angular Dim Line
jsese4RXCF
jsese4RXCF
Kindly give me a solution in fixing the annotation text height in isometric extraction and how to remove the angular dimension line in an offset piping. Please refer to the attachment. Appreciate your help.
JUANCARLOSBLASCO4129
Hi
In Project Set Up > Isometric DWG Settings > Annotations
You can set text height
For removing the angular dimension, you need to edit isoconfig.xml.
See around line 221 or so:
2.JPGBy default it's set to DimAngularWithSuffixAndArc, and can be  modified to:
'DimAngularOff', 'DimAngularWithoutSuffixNorArc', 'DimAngularWithSuffix', 'DimAngularWithArc', or 'DimAngularWithSuffixAndArc'.
EDIT:
Seems you can remove the angle annotation in project setup too, without need to edit isoconfig.xml:
Regards
jsese4RXCF
Thanks for the reply.
Our project is in imperial, so under project setup, isometric dwg settings, annotation:
Text
Height and Enclosure = 0.1
Unfortunately, it did not worked.
In the isoconfig.xml, line 221, do I need to delete either one of those DimAngular...?
In the Project setup, Isometric dwg settings, Sloped and Offset Piping, I've uncheck the box for Display offset angle annotation, unfortunately, the angular dim line and the angle annotation both gone, I only need the angular dim line to be remove.
