Hello @MARTINAMEDEO2597
Not so simple, your request, the research of which is very interesting.
To arrive a result you sometimes have to think differently than the logic of Plant 3D !!!
Step 1, you must create the axis of the 3D piping line. For this you can download the Lisp program (French) that I have provided for download. It is called AP3D_AxeT. Here is the link:
https://dovaq.fr/download/1061/?tmstv=1728762927
The “Ap3D_AxesT” command which creates the axis lines and places them on the “AP3D_Axes_Tuyauterie” layer
The “AP3D_EffacerAxesT” command which allows you to erase all the objects on the “AP3D_Axes_Tuyauterie” layer
Step 2, put every X distances a reference point. To do this, we can use the MEASURE command which will place points every X distances.
By setting the system variable "PDMODE" to 3 you can see the position of the points.
Step 3, place on each point of the 3D line, a pipe component (50 mm long) which will be recognized by the Ortho view but which will not be linked to the pipe line so as not to disturb the isometric output of the line 3D.
Step 4, in the project configuration, we create a new calculated property "Elevation Z" on a pipe
Step 5, in the project configuration, we add a new annotation which includes the Z value of the pipe component in ortho.
Step 5, create the Ortho view and annotate the elevation by selecting the small piece of pipe. In this we should see the components placed on the points at X distances.
Step 6, we place on the ortho view the annotation of the Z value on each point.
Notes:
The fact that this small pipe component is not connected to the line, it will not come out isometric. In addition, it can be made invisible in the ortho view by freezing or making its layer inactive.
If the 3D view changes, the positioning of the components will need to be taken into account so that when the ortho view is updated, the elevations are updated correctly.
In the 3D view, it is possible to make these components invisible by playing on their layer.
Watch the explanatory video
=== French ===
Pas si simple votre demande dont la recherche est très intéressante.
Pour arriver à un résultat il faut quelquefois réfléchir différemment que la logique de Plant 3D !!!
Etape 1, il faut créer l'axe de la ligne de tuyauterie 3D. Pour cela vous pouvez télécharger le programme Lisp que j'ai mis en téléchargement. Il se nomme AP3D_AxeT. Voici le lien :
La commande « Ap3D_AxesT » qui permet de créer les traits d’axe et les place sur le calque « AP3D_Axes_Tuyauterie »
La commande « AP3D_EffacerAxesT » qui permet d’effecer tous les objets sur le calque « AP3D_Axes_Tuyauterie »
Etape 2, mettre tous les X distances un point de référence. Pour cela on peut se servir de la commande MESURER qui placera des points tous les X distances.
En réglant la variable système "PDMODE" à 3 on peut voir la position des points.
Etape 3, placer sur chaque point de la ligne 3D, un composant tuyau (50 mm de long) qui sera reconnu par la vue Ortho mais qui ne sera pas lié à la ligne de tuyauterie afin de ne pas perturber la sortie isométrique de la ligne 3D.
Etape 4, dans la configuration du projet, on crée une nouvelle propriété calculée "Elevation Z" sur un tuyau
Etape 5, dans la configuration du projet, on ajoute une nouvelle annotation qui reprend la valeur Z du composant tuyau en ortho.
Etape 5, création de la vue Ortho et annotation de l'élévation en sélectionnant le petit morceau de tuyau. Dans celle-ci on devrait voir les composants placés sur les points à X distances.
Etape 6, on place sur la vue ortho l'annotation de la valeuir Z sur chaque point.
Notes :
Le fait que ce petit composant tuyau ne soit pas connexté à la ligne, il ne sortira pas en isométrique. De plus il pourra être rendu invisible dans la vue ortho en gelant ou en rendant inactif son calque.
Si la vue 3D change, il faudra prendre en compte le positionnement des composants afin que lors de la mise à jour de la vue ortho, les élévations se mettent correctement à jour.
Dans la vue 3D, il est possible de rendre ces composants invisibles en jouant sur leur calque.
Cordialement
Dominique VAQUAND
www.dovaq.fr
Cette publication vous a-t-elle été utile ? N’hésitez pas à attribuer la mention J’aime à cette publication.
Avez-vous obtenu la réponse à votre question ? Cliquez ensuite sur le bouton ACCEPTER LA SOLUTION.
