Adjustable Welded Stanchion
≡ EqVert ≡
≡ EqVert ≡
On Plant 3D ver.2019.1
Pipe support Adjustable Welded Stanchion is installed with a diameter less than the pipeline
Why ...
It looks like a mistake.
Is there any way to correct this action
Right-click > Properties you can change all the dimensions.
I prefer my support diameter to be less than the pipe diameter, it makes welding it on easier.
≡ EqVert ≡
It's not about preferences, but about standards. A smaller support will not be able to hold the load from a larger pipeline.
Moreover, this behavior is only for supports that are installed on the pipe bends
VinodBalasubramanian
Autodesk Support
Autodesk Support
Can you check this one and see if that helps to fix,
https://knowledge.autodesk.com/support/autocad-plant-3d/troubleshooting/caas/sfdcarticles/sfdcarticl...
Vinod Balasubramanian
AutoCAD Industry Support & Escalation Lead
