I am trying to add the sheet number, for a single sheet isometric, to the DWGNAME and the FILENAME. I edited the IsoConfig.xml file for both parameters but, only the DWGNAME was successful. Does anyone know why the FILENAME does not include the sheet number? I am using Plant 3D 2017.1 update.
Attached are excerpts from the Isoconfig.xml file and the Isometric output.
Hi @maxpiper
i can not reprocess this problem!
For me the standard configuration works Final A3
With me everything is in order see picture.
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
I have tried every out of the box Isometric profile but, cannot add the sheet number to the Filename. Can you show me the changes you made to your IsoConfig.xml to obtain the results you are showing?
Hi @maxpiper,
i have not made any changes to the Iso configuration!
I am working with Plant 3D 2017 Standard Iso configuration Final_A3.
Hartmut Eger
Senior Engineer
XING | LinkedIn
Harmut, I noticed that your test isometric has two sheets (SHT 1 OF 2). Can you test on an isometric that has only one sheet (SHT 1 OF 1)?
Hi @maxpiper,
Hartmut Eger
Senior Engineer
XING | LinkedIn
Hartmut,
As you can see from your test, the sheet number is not added to the Iso FileName or DwgName. I am trying to get the sheet number added when the Iso only has one sheet. After I edit the FileName and DwgName options in the IsoConfig.xml, the DwgName includes the sheet number but, the FileName does not include the sheet number.
IIRC Sheet number only applies to ISO's which have multiple sheets.
Hi @maxpiper,
50% success
Filename = ok
DrawingName = is hardcoded and not yet editable Info after consultation with autodesk support.
The following change in IsoConfig.xml
In the FileNameFormat section, set the value AutoIncludeSheetNumber from false to true (1)
The result
Hartmut Eger
Senior Engineer
XING | LinkedIn
I have set the "autoincludesheetnumber" to "true" yet my sheet number still does not show in my filename unless I have 2 sheets. Any clues as to what is going wrong here?
Standard and bespoke PLANT3D Training and ACAD Training and ACAD ELEC Training
I also having the same issue. Unless the sheet are more that 1, it does not add that prefix.
But better to have it even when it is one sheet.
Have you found any work around for that?
Also: Any solution for having the filename as drawing number in the sheet?
@chris.downing wrote:I have set the "autoincludesheetnumber" to "true" yet my sheet number still does not show in my filename unless I have 2 sheets. Any clues as to what is going wrong here?
Hi, any progress on this theme with the latest versions?
Our client have a file name format that has to have a sheet number appended to isometric number, even with a single sheet.
thanks
