AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Add sheet Number to Isometric Filename
12 REPLIES 12
Message 1 of 13
maxpiper
1318 Views, 12 Replies
I am trying to add the sheet number, for a single sheet isometric, to the DWGNAME and the FILENAME. I edited the IsoConfig.xml file for both parameters but, only the DWGNAME was successful. Does anyone know why the FILENAME does not include the sheet number? I am using Plant 3D 2017.1 update.
Attached are excerpts from the Isoconfig.xml file and the Isometric output.
12 REPLIES 12
Message 2 of 13
h_eger
in reply to: maxpiper
Hi @maxpiper
i can not reprocess this problem!
For me the standard configuration works Final A3
With me everything is in order see picture.
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
Message 3 of 13
maxpiper
in reply to: h_eger
I have tried every out of the box Isometric profile but, cannot add the sheet number to the Filename. Can you show me the changes you made to your  IsoConfig.xml to obtain the results you are showing?
Message 4 of 13
h_eger
Hi @maxpiper,
i have not made any changes to the Iso configuration!
I am working with Plant 3D 2017 Standard Iso configuration Final_A3.
Hartmut Eger
Senior Engineer
XING | LinkedIn
Message 5 of 13
maxpiper
in reply to: h_eger
Harmut, I noticed that your test isometric has two sheets (SHT 1 OF 2). Can you test on an isometric that has only one sheet (SHT 1 OF 1)?
Message 6 of 13
h_eger
Hi @maxpiper,
Hartmut Eger
Senior Engineer
XING | LinkedIn
Message 7 of 13
maxpiper
in reply to: h_eger
Hartmut,
As you can see from your test, the sheet number is not added to the Iso FileName or DwgName. I am trying to get the sheet number added when the Iso only has one sheet. After I edit the FileName and DwgName options in the IsoConfig.xml, the DwgName includes the sheet number but, the FileName does not include the sheet number.
Message 8 of 13
ryan.bales
IIRC Sheet number only applies to ISO's which have multiple sheets.
Ryan Bales
Fusion 360 Product Support
Message 9 of 13
h_eger
in reply to: ryan.bales
Hi @maxpiper,
50% success
Filename = ok
DrawingName = is hardcoded and not yet editable Info after consultation with autodesk support.
The following change in IsoConfig.xml
In the FileNameFormat section, set the value AutoIncludeSheetNumber from false to true (1)
The result
Hartmut Eger
Senior Engineer
XING | LinkedIn
Message 10 of 13
chris.downing
in reply to: h_eger
I have set the "autoincludesheetnumber" to "true" yet my sheet number still does not show in my filename unless I have 2 sheets. Any clues as to what is going wrong here?
ACADE & PLANT3D Applications Engineer
CAD Training
Standard and bespoke PLANT3D Training and ACAD Training and ACAD ELEC Training
Message 11 of 13
sghazagh
in reply to: chris.downing
I also having the same issue. Unless the sheet are more that 1, it does not add that prefix.
But better to have it even when it is one sheet.
Have you found any work around for that?
Also: Any solution for having the filename as drawing number in the sheet?
Message 12 of 13
mikael.santospj
Hi, any progress on this theme with the latest versions?
Our client have a file name format that has to have a sheet number appended to isometric number, even with a single sheet.
thanks
Message 13 of 13
R4M3SS3S
in reply to: mikael.santospj
Apparently still no solution to this well known issue?
Autodesk... 🤢
”Boost
