Add new spec file into project.
rafimh2022
rafimh2022
Dear All,
I have a new spec file and cad block received from another project and I copied into my project spec folder. I can see the file through Spec editor but not visible through Project manager "Pipe Specs" list.
May I know how to add spec into a project?
Rafi.
h_eger
@rafimh2022 ,
Is it a new spec or one that you are already using in the P3D project?
If it is new then right click on the Pipe Spec folder in your P3D project and Copy Specs to Project...
If you already have it in use it is a bigger effort to write it down.
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
rafimh2022
Hi @h_eger Sir,
Thanks and added spec and when am trying to add items into model it shows a error message
Do I need to copy the Catalogue files as well for those spec items? Including blocks?
Rafi.
h_eger
@rafimh2022 ,
did you only receive the two pipe spec files *.pspc and *.pspx or also the content folder with the catalog data and the associated files?
Here is an example of what you need:
Hartmut Eger
Senior Engineer
XING | LinkedIn
