add new python file to spec editor
DGRL
Advisor Advisor
DGRL
Hi
Is it possible to add python files to the spec editor? Now Plant 3D comes with a standard selection of for example supports. I would like to add a few extra. I know the variants.zip file but is this file used by the spec editor?
ANd if yes can i just add newly made compiles (PYC) python files to it?
If this was of any help please kudo and/or Accept as Solution
Kind Regards
h_eger
Dear @DGRL ,
new Python scripts can only be added to the SpecEditor via user-defined Python scripts.
There is no other way to make Python scripts available in Plant 3D.
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
DGRL
Dear @h_eger
Thanks for your answer. I assume that the scipts needs to be placed in this folder,
AutoCAD Plant 3D 2019 Content\CPak Common\CustomScripts. Am i correct?
Kind Regards
h_eger
Hi Don,
yes this is the place.
We need the * .py files in this folder.
Then execute the "PLANTREGISTERCUSTOMSCRIPTS" command in Plant 3D.
With this command "PLANTREGISTERCUSTOMSCRIPTS" you commpillate from the "* .py" files * .pyc files.
Attached is the documentation for the Python user scripting.
Hartmut Eger
Senior Engineer
XING | LinkedIn
DGRL
@h_eger
I did it in a slightly different way.
See the files below. I added them in the customscripts folder
Now this becomes available in speceditor and After restarting P3D you can place the spec item
In this case i made an custom support with a param that can change the angle of the brackets.
Standard this is 90 degrees in P3D and now i can make them any angle I like (45 degrees is mostly used in the world)
Thanks @h_eger
Kind Regards
George.Endrulat
Can you provide another link to that file?  It only says that the site has closed the connection and I can't download it.  Thank you.
George
If my post offers a solution, please click "Accept as Solution"
DGRL
@George.Endrulat
I just downloaded the file again. Seems to work
Kind Regards
