This query is in regard for Piping & Equipment Modelling to be done using point cloud data.
1. Detail procedure in customizing the point cloud data (*.rcp & *.rcs) in Plant 3D.
2. Configuring the supplied Piping Spec/Catalog inside Plant 3D.
3. How to match the pipe spool & pipe fittings with point cloud data.
4. If the point cloud data shows deviated pipes like the ones that are not horizontally straight, how to model such pipes in Plant 3D (As-Built) ?
5. Generating ISO drawings and settings required for its customization.
Thanks in advance!
Regards
Beldwin
Hi Bferrao,
Congratulations on your first post, and welcome to the forums!
I have attached a couple links below that will help you get started, with your request. Seeing how you're asking for an entire workflow on how to complete this type of project, the best I can do is supply some credible resources. As for getting more familiar with the product, we always recommend our users to look through the product help, tutorials found on on the Autodesk Knowledge Network, and any of the available classes from Autodesk University.
About Working With Point Clouds
Models typically represent an idealized situation, rather than real-world. We slope lines where they are intended to be sloped, but otherwise draw them straight and true in a best-fit position. Same thing with equipment and structure.
Matching fittings, valves, pipe, etc. to a point cloud is done using pictures, existing documentation, and experience.
Thanks for your reply,
I had gone through the video tutorials but could get any specific one that addresses my issue, if you can kindly share the tutorial that is an answer to my issues.
Regards
Beldwin
So simply saying, its not possible to model pipes as seen in cloud data and have to be modeled straight (horizontal&vertical) as how its done in design.
Beldwin
Right. One of the benefits of laser scanning is that it can be done in place without shutting down the facility. So there may be some twists and bends due to thermal expansion which you don't want to model. There may be field routed pipe that is "off" in order to get around something else which should be modeled that way. Then you get to things like field-routed tubing, handrails, and mystery conduit.
