AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
3D Ortho view boundaries reset whenever I edit the view
4 REPLIES 4
jacob.ellerbrock
241 Views, 4 Replies
Whenever I edit a view in a Plant 3D drawing, the viewport always resizes back to its default input. I then have to rescale and recrop everything I want. Not to mention reattach any leaders and such I have attached to the drawing. Is there a way to not make it go back to that initial size? I know when I update a view it doesn't change but get frustrated when it does this with the edited view.
Labels (1)
4 REPLIES 4
h_eger
in reply to: jacob.ellerbrock
Dear @jacob.ellerbrock ,
This way of working when updating ortho views is known. The only way left is either to set the view size correctly when creating it or to edit the ortho view window after each update.
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
jacob.ellerbrock
in reply to: h_eger
If it is known, is there plans to change it and/or improve it or is it left alone?
jacob.ellerbrock
in reply to: h_eger
How would you go about this? I'm curious if there is a correct way?
h_eger
I have tried to reproduce your problem in P3D 2023 but unfortunately without success. In my ortho it doesn't matter if I change the viewport's size after creating the view. For me, the view window remains the same size as I modified it, no matter how often I refresh the ortho view.
Hartmut Eger
Senior Engineer
XING | LinkedIn
Technology Administrators
