2023 Spec Editor will not allow cut and paste.
dmgraves
Message 1 of 14
dmgraves
Replies (13)
Message 2 of 14
h_eger
Dear @dmgraves ,
can you please describe the cut and paste process in more detail in Spec Editor 2023 as it works fine for me.
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
Message 3 of 14
dmgraves
Right click on item.  Select copy. Right click to use paste, but it is greyed and faded and does not function.  Ctrl+c & Ctrl+V same situation.  Does not paste.  Could you detail out how yours works for you?
Message 4 of 14
h_eger
Works with Spec Editor -> Catalog Editor
with right mouse click on the object copy and again right mouse click paste and the selected object is created with the entry *%copy
Hartmut Eger
Senior Engineer
XING | LinkedIn
Message 5 of 14
dmgraves
Copy yay...
Paste boooo
This used to work and suddenly stopped
Message 6 of 14
h_eger
No in the SpecSheet you can not copy objects!!!
How should this work?
Hartmut Eger
Senior Engineer
XING | LinkedIn
Message 7 of 14
dmgraves
It was working until yesterday
Message 8 of 14
h_eger
Are you sure that this worked yesterday?
I do not believe it because this has not worked since 2009-2023. 😉
Hartmut Eger
Senior Engineer
XING | LinkedIn
Message 9 of 14
dmgraves
No. It was working UNTIL yesterday.  Was working all the way up to day before yesterday and was not working yesterday.  Yeah I'm sure.
Message 10 of 14
dmgraves
It was 2020.  Started using 2023 spec yesterday.
Still works in 2020 as seen here.  Believe it or not.
Message 11 of 14
h_eger
In the Spec Editor 2020 this was possible (error in the programming) with version 2021 this mode of operation is blocked so writes it in any case the development department.
Hartmut Eger
Senior Engineer
XING | LinkedIn
Message 12 of 14
dmgraves
Ah. So this:
Was in error.😛
Message 13 of 14
jabowabo
I keep an old version installed to one PC just to copy/paste items in specs. Disappointing that it doesn't work in the newest version(s). It has never worked for me in 2023.
Message 14 of 14
dmgraves
Yeah.  I have gone back to using my 2020 spec editor this morning and will continue to use it until Autodesk gets more customer and user friendly.
