Announcements
2022 Plant 3D LDT Mapping
jcaldwellDS6YF
jcaldwellDS6YF
Yesterday (11/13/24) I had the LDT Mapping working correctly. Then something happened and I do not know what it is. But now it cannot sync the Excel Spreadsheet. I have tried exporting out from the Data Manager but no matter where I try to save the file it keeps telling me "File Exists" and it will not export the file. I have tried with existing Projects and have Created new Project using all default settings and I keep getting the same errors. Can anyone help me?
Jeremy
Replies (12)
Tomislav.Golubovic
That doesn't make sense, no matter where you save the file it says "File Exists"?
jcaldwellDS6YF
that is correct. It seems that something is corrupt. I just tried to save my model and got the same error.
Tomislav.Golubovic
Restarted PC?
DVaquand
Hello @jcaldwellDS6YF
Try to empty the Plant 3D cache by running "PnPLocalDataCachePurger.exe", file located in the folder "C:\Program Files\Autodesk\AutoCAD 202x\PLNT3D
== French ==
Essayez de videz la mémoire cache de Plant 3D en lançant "PnPLocalDataCachePurger.exe", fichier placé dans le dossier "C:\Program Files\Autodesk\AutoCAD 202x\PLNT3D
Cordialement
Dominique VAQUAND
www.dovaq.fr
Cette publication vous a-t-elle été utile ? N’hésitez pas à attribuer la mention J’aime à cette publication.
Avez-vous obtenu la réponse à votre question ? Cliquez ensuite sur le bouton ACCEPTER LA SOLUTION.
jcaldwellDS6YF
Still received this error when trying to save the drawing in the Project:
jcaldwellDS6YF
Yes I have restarted mulptiple times and still same result.
jcaldwellDS6YF
I have uninstalled 2022 Plant 3D and Reinstalled it and i am getting the same issues. I cannot add any drawings to any project. I cannot create any new Drawings for any Projects. I cannot export from Data Manager to excel files. I am trying to map Attributes using the LDT Table but something happened on Wednesday and I do not know what. I have tried all i can think of. I just keep getting the following error:
At this point, I am at a loss.
jcaldwellDS6YF
This is what I get when adding an LDT File to Map:
h_eger
@jcaldwellDS6YF ,
are you using an *.xls or *.xlsx as the LDT file?
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
jcaldwellDS6YF
i was trying both of them.
jcaldwellDS6YF
I found an answer to this from another Thread. They had mentioned to clear out the Temp Folder. After doing that all is well with the syncing of the Line Designation Table. Now the issue is, it is now reading information from the column after it is supposed to. I am working thru that now. If you have had this issue please let me know if youhad a fix.
Michiel.Valcke
Usually this error comes from a corrupted installation or windows profile:
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/FailedToSaveDrawin...
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
