Thank you always for your comments, I share a drawback that I am having with the new version.
Updated the Report Builder version 2017, appears blank. Could you share info about
-have been configured for my company in the 2014 version, where is the template saved? Can you recover?
-How can you take the basic reports to modify?
Thank you very much, regards greetings
Solved by h_eger. Go to Solution.
Hi @Anonymous,
the report files of the Plant 3D 2014 version are located under the following directory:
c:\ProgramData\Autodesk\AutoCAD Plant 3D 2014\R19.1\enu\ReportCreator\ReportFiles\
In the Report Creator under settings the directories with the template reports are set.
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
hi @Anonymous
After installing the 2017 version please go to settings as described by @h_eger
Navigate to the project folder of the reports you made using the custom path option and change the path.
Now you should be able to see the reports again
Hi, thanks for your advice.
Please, check images below.
I think, i have it setting well.
I cant find a reason why i can not visualize any template or existing report 😞
Thanks in advance for your advices.
there are no *.rcf files in your directory ...
Which files are in thew subdirectory 'ReportFiles'
I think this should be set in the settings
Hi @Anonymous,
you have almost reached the goal!
See picture:
The folder "ReportFiles" contains files with the ending * .RCF
These are the template files for the reports.
Hartmut Eger
Senior Engineer
XING | LinkedIn
