法兰凹凸面
法兰凹凸面
80944291
4,959 次查看
11 条回复
1 条消息(共 12 条)
法兰凹凸面
80944291
元件库法兰密封面形式,只有RF,FF,RTJ三种形式,如何自定义法兰凹凸(M/FM)面形式,并如何设置凹凸面自动匹配
0 个赞
4,960 次查看
11 条回复
回复 (11)
2 条消息(共 12 条)
h_eger
@80944291 ,
Unfortunately you have landed in the English Plant 3D forum.
You can find the Chinese Plant 3D forum here:
https://forums.autodesk.com/t5/zhong-wen/ct-p/531
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
3 条消息(共 12 条)
Michiel.Valcke
Hello @80944291
The RF/FF/RTJ facings are just text that is filled in in the facing property of any flanged part in the catalog.
You can modify and edit your catalog to make new parts with different facing values.
https://help.autodesk.com/view/PLNT3D/2025/CHS/?guid=GUID-40C579AC-DD7A-471B-BBCF-1818E8A3B81E
To set up a groove and tongue connection you will need to also adapt your project settings (joint setup). This is all a bit too elaborate to explain in a single forum post. Did you have any training or do you have a software reseller in your region that can help you?
I wrote an article about the groove / tongue setup in Plant 3D a while ago. It's in dutch, but any online translate app can help you get the essence.
4 条消息(共 12 条)
Michiel.Valcke
for some reason the autodesk forums keep changing the URL, there is a series of numbers in the URL and the forum thinks it's a phone number so they get changed to xxx-xxxxxxxxxxxx. Just give me a PM (in English / Dutch / French ) if you want the link to the article.
0 个赞
5 条消息(共 12 条)
张文潇|夜开荼蘼
已接受的解答
1、通过PLANTENDCODES新建两种连接类型M,FM。注意是连接类型不是密封面型式。
2、设置凸法兰的端点型式为M/BV,密封面为MFM;凹法兰的端点型式为FM/BV,密封面为MFM;螺栓垫片的密封面为MFM;
3、设置简单连接,M对FM,必需匹配项为直径、密封面、压力等级,紧固件为垫圈和螺栓组;
4、设置两个组合式连接。凹面法兰连接端点1选FM,法兰的端点类型选M;凸面法兰的端点1选M,法兰端点类型选FM;
这样就可以实现凹凸面的匹配连接了。
注:仅通过密封面是无法实现凹凸面的匹配连接的。
张文潇
[email protected]
Senior Engineer
Jiangsu SOPO Engineering Technology CO. LTD.
静守时光 以待流年
6 条消息(共 12 条)
80944291
还有一个问题请教一下,当我在管线上插入一个凹面法兰时,系统如何自动匹配另一个凸面法兰
0 个赞
7 条消息(共 12 条)
张文潇|夜开荼蘼
你按照我以上方法做的就是凹凸面自动匹配的。插入凹面法兰自动生成凸面法兰,插入凸面法兰自动生成凹面法兰。
张文潇
[email protected]
Senior Engineer
静守时光 以待流年
8 条消息(共 12 条)
80944291
我的在管线中插入法兰怎么提示是这样的,请指点一下
80944291_0-1734060769775.png我的在
0 个赞
9 条消息(共 12 条)
张文潇|夜开荼蘼
已接受的解答
把端点2加入PL就可以了,参照自动法兰连接
张文潇
[email protected]
Senior Engineer
静守时光 以待流年
10 条消息(共 12 条)
80944291
谢谢大神
0 个赞
11 条消息(共 12 条)
80944291
当我在管线中插入端点类型为M点的法兰时,其自动匹配的法兰端点为FM,这是正确的,当我在管线插入端点为M的阀门时,阀门两侧自动匹配的法兰端点也是M而不是FM,当我在管线插入端点为FM的阀门时,阀门两侧自动匹配的法兰端点也是FM而不是M
0 个赞
12 条消息(共 12 条)
张文潇|夜开荼蘼
已接受的解答
参照我的简单连接,端点1是M,端点2是FM,你不能把M和FM都放到端点1或2里。不然就承认了M与M也可以连接。 在组合式连接里,端点1为FM,但是在法兰端点里,需要适配M,你填FM就不对。具体的你再检查一下设置。按照我这个设置M和M,FM和FM是不能生成垫片的。
张文潇
[email protected]
Senior Engineer
静守时光 以待流年
