Trace Edit Issue
Trace Edit Issue
co_daddy
Observer Observer
Trace Edit Issue
co_daddy
Observer
Observer
I ended up doing a drawing in. TRACEEDIT mode and not in TRACEVIEW mode. How can I get the work I did in TRACEVIEW mode into a drawing?
jeremy.goldman
Hey there. Use the COPYFROMTRACE command.
1. Open the trace with the geometry you want to copy into the drawing.
2. Switch to Trace View mode.
3. Type COPYFROMTRACE and press Enter.
4. Select the geometry to add to the drawing.
5. Press Enter to confirm the selectio set.
Jeremy Goldman
Senior Learning Content Developer, AutoCAD
co_daddy
Observer
Observer
Perfect! Thank you!
