Shortcut Menus don't work correct
baranova_iryna
baranova_iryna
Shortcut Menus does not work correctly when selecting command options with a mouse in Russian. For example, when drawing a rectangle, the selection of the Dimensions command is not accepted - and there is a constant request to repeat the keyword.
At the same time, entering a keyword from the keyboard works.
mwn
I'm seeing a difference between English and Russian.  I'll let the team know and get back to you.
Best regards,
-mike
“https://damassets.autodesk.net/content/dam/autodesk/logos/autodesk-logo-primary-rgb-black-small_forum.png”
