Processing failed
Processing failed
thaipham
Processing failed
thaipham
I upload the 3d model on Autodesk Viewer. the first day, I can open the file and shared with my colleagues, my colleagues also can open the file for the first day. but the second day, when I open the file and it said: "The processing operation timed out. Please try again", but the file still have 29 days to go. But when I retry to re-generate the same file and upload again, it works.
mwn
Are you using https://web.autocad.com?
-mike
“https://damassets.autodesk.net/content/dam/autodesk/logos/autodesk-logo-primary-rgb-black-small_forum.png”
thaipham
No,
I am using : https://viewer.autodesk.com
mwn
This forum is specifically for AutoCAD web.  You will have better luck in the A360 forum here:  https://forums.autodesk.com/t5/a360-forum/bd-p/205
Best regards,
-mike
