line width
line width
isabellemouramonteiro
line width
how I change the line thickness in the web version
Thomas_Stuehle
Hello @isabellemouramonteiro
Welcome to the Autodesk Web App Forum.
I would recommend the following steps for two different situations:
  1. You only have the AutoCAD Web App
  2. You also have AutoCAD Desktop available on the side
  1. LWDISPLAY is not available in the Autodesk Web App. So you can not switch on/off the Lineweight. But the AutoCAD Web App shows the difference when your drawing has it already switched on.
  2. Download the attached file Line_Width. I created it for you and the variable is already switched on.
  3. You can upload it to your Web App File Manager and use it as a template.
  4. Select and Duplicate it if you need to.
1. Open AutoCAD Desktop
2. Switch LWDISPLAY on
3. Change the Lineweight of the lines in the properties palette (as shown in the screenshot below)
4. Save the file and upload it to the AutoCAD Web App File Manager
5. Open the file - the lineweight is shown. It also works for new lines you will create.
6. You can change the lineweight also in the properties palette.
Did the post help you and answered your question? If yes, feel free to click on the button "Mark as Solution". Thus also other users can benefit from the information. In case you still need help please feel free to provide an update here so we as Community know how we can help you best moving forward.
Best regards,
Thomas
Your question got successfully answered? Then just click on the 'Mark as solution' button.
Thomas Stühle
Technical Support Specialist
Thomas_Stuehle
Hello Isabelle @isabellemouramonteiro
Did the post above helped you and answered your question?
Best regards,
Thomas
Thomas Stühle
ivan_henderson
Community Visitor
Community Visitor
Thank you so much! Finally - Line weight! Now to solve world hunger! 😅
