Edit Blocks in Autocad Web app
Message 1 of 12
It's my first time using AutoCAD on any platform and I'm just learning so I'm using the free web app to get my bearings.  I can't seem to find a way to edit blocks.
I can create blocks, for instance rectangle to represent a shower.  I can place and copy the shower block but I can't change it, for instance to add or move details like a drain to all instances by editing the block object.
I feel like object classes "blocks" and instances are critical core functionality so it's frustrating not to be able to find it, I would sure appreciate a pointer in the right direction.
Replies (11)
Message 2 of 12
https://blogs.autodesk.com/autocad/10-things-you-need-to-know-about-the-autocad-web-app/
#7 "The Blocks palette allows you to view and modify the blocks in your drawing"
But for the life of me I can't figure out how to modify a block.
Message 3 of 12
Thomas_Stuehle
Hello @Anonymous
Welcome to the AutoCAD Web App forum.
Please try the following steps when you want to change an existing block:
  1. Select the block object.
  2. Enter EXPLODE in the command line.
  3. Modify the object(s).
  4. Save the drawing.
  5. Enter BLOCK or -BLOCK again.
  6. Enter the old block name.
  7. The system tells you that the block name already exists and asks if you want to redefine it.
  8. Agree to redefine.
  9. Follow the rest instructions in the command line.
Did the post helped you and answered your question?
If yes, feel free to click on the button "Mark as Solution". Thus also other users can benefit from the information. In case you still need help please feel free to provide an update here so we as Community know how we can help you best moving forward.
Best regards,
Thomas
Your question got successfully answered? Then just click on the 'Mark as solution' button.
Thomas Stühle
Technical Support Specialist
Message 4 of 12
Excellent!  That works.  It's a different workflow than I'm used to but it works all the same.
Message 5 of 12
pendean
Community Legend
Community Legend
>>>... It's a different workflow than I'm used to...<<<
That's how we used to do it 30+ years ago in AutoCAD in DOS 🙂
BACK TO THE FUTURE!!!!
Message 6 of 12
It's not the worst thing I've ever seen but it makes nested blocks either impossible or messy.
But hey I'm only 6 hours in, what do I know?
Message 7 of 12
Thomas_Stuehle
Perfect - I am happy that it works for you too 🙂
Thomas Stühle
Message 8 of 12
sabahalajrab
Community Visitor
Community Visitor
It's the worst thing I've ever seen.
Message 9 of 12
vladimir_michl
Alternatively, you can trick AutoCAD Web app by calling the old block editor with:
(command "-REFEDIT")
performing the changes and exiting the block editor with
(command "-REFCLOSE")
Vladimir Michl, www.arkance-systems.cz  -  www.cadforum.cz
Message 10 of 12
vladimir_michl
You can now unlock the standard REFEDIT/REFCLOSE commands - see the tip:
https://www.cadforum.cz/en/adding-the-block-editor-to-autocad-web-app-tip13607
and see the video:
Message 11 of 12
wayan_c
Community Visitor
Community Visitor
There is AutoCAD in Dos? I thought it was a new software.
Message 12 of 12
pendean
Community Legend
Community Legend
AutoCAD on PC is 40+years old now: it is updated and made to look modern, but a lot of the old clunkiness is still present in it's many iterations on a MAC and in Mobile/Web too.
