AutoCAD on the web - Cannot exit ARRAYEDIT mode
Message 1 of 11
Hi, when I enter ARRAYEDIT mode, I can edit my array but there is no way to exit/ close the edit and save the work. It eternally remains in the ARRAYEDIT mode, and when I try to save the file it says "Caching..." (of course it does not save the file as it's in the middle of a command!)
[ The subject line of this post has been edited for clarity by @handjonathan Original: Cannot exit ARRAYEDIT mode ]
Replies (10)
Message 2 of 11
pendean
Community Legend
Community Legend
Are you in the webapp? It's not a fully fleshed out version, it has its quirks, enjoy the ride.
Message 3 of 11
Yep, webapp...it's an annoying bug!
Message 4 of 11
acadhelp1
@Anonymous
I'm sorry this is not working for you.  Let me see if I can get some info about the problem.
How are you starting the ARRAYEDIT?  double click the array or from the command line?
If you have a drawing that is particularly, could you share it?
Jon
Jon Page
AutoCAD Design Manager
Message 5 of 11
Hi Jon,
I used ARRAYEDIT from command line. I share a reproducible test DWG for you. It's a simple array.
It seems that ARRAYCLOSE is not included in the web app, which is critical to finish editing an array. When I enter ARRAYCLOSE, it says Unsupported Command!
Message 6 of 11
mwn
ARRAYCLOSE is not supported in the AutoCAD web app but its not needed. The command line has an eXit option that ends the command. Both <enter> and <esc> will end the command with any changes updating the Array. In the screen shot you can see I changed the number of columns in an array and am still in the command.  At this point <esc> or <enter> will end the command with the number of columns updated.
Best regards,
-mike
“https://damassets.autodesk.net/content/dam/autodesk/logos/autodesk-logo-primary-rgb-black-small_forum.png”
Message 7 of 11
Hi Mike,
Thanks, but it only works when you change number/spacing of columns and rows.
Try the following to reproduce my result:
build an array, then try to edit the source of the array (eg, scale the size of the source). In this scenario, you would not be able to close/exit edit. Interestingly, when I select the source item of my array, this note appears on the command line: "Entre ARRAYCLOSE to exit array editing state"
See screenshot attached.
Message 8 of 11
mwn
Ugh, clearly I didn't dig deep enough.  I'll log a bug and we'll get it fixed.
Thank you for letting us know.
-mike
Message 9 of 11
Thomas_Stuehle
Hello @Anonymous
Did the post by @mwn help you and answer your question?
-mike
If yes, feel free to click on the button "Mark as Solution". Thus also other users can benefit from the information. In case you still need help please feel free to provide an update here so we as Community know how we can help you best moving forward.
Best regards,
Thomas
Your question got successfully answered? Then just click on the 'Mark as solution' button.
Thomas Stühle
Technical Support Specialist
Message 10 of 11
Hi @Anonymous ,
As far as I can see, the issue still exists in AutoCAD web.
@mwn mentioned his team is working on a fix. I'm unsure how long it takes. When it's resolved, I expect to receive a notification from you/ Mike, then I'll mark that notification as a solution. I hope it makes sense.
Message 11 of 11
daniel.herrmann.planner
Community Visitor
Community Visitor
Hi Thomas,
Im experiencing the exact same issue as this user.
Has a solution been identified yet?
Id love to know before shutting down the drawing that is unsuccessfully trying to save.
Kind regards
Dan
