Show only
Search instead for
Submitted byAnonymouson11-20-201710:07 AM
Status:
Gathering Support
3D Trim
I think there should be present separate 3D Trim option. Sometimes present trim tool cause some problems in some complex 3D drawings. Working become easier if 3D trim is their with 3D working capabilities.
AutoCADMobile, the forum you are posting in, has no 3D capabilities, so adding one 3D command makes no sense.
If you are using some other software, consider posting in that forum instead as I bet there probably is an answer to your solution or at least a workaround.
