How create ad interface between Autocad and a documental / management sw?
I'm following a development project where one of the feature is an interface between the main (documental and managerial Sw web based) to AutoCad.
The feature have to allow:
  1. to open a dwg file, storaged on a local server, using ID that allow to identify the file called;
  2. to update the design adding new objects (area, lines or points) choosing the layer from a pre-defined list of layer or deleting existing objects;
  3. to send the list of layers and their properties to the sw which provide to record them in a SQL Server and process them too;
  4. to "save as ..." the file, it must be sotaged in the same folder of the older one.
Could I use API? If yes, which one?
Is it AutoCAD360 the right AutoDesk app to use?
Or where could I found the usefull information to resolve this problem?
The attachment is a screen shot of the esxisting feature (developed in VisualBasic and use AutoCad2012):
  • AutoCadInt0: screen of the sw from where the user can call AutoCad and open the dwg file into the interface
  • AutoCadInt1: screen of the opened dwg, detail on the layer user (rig-l) that is into the list of available options (red highlighted section)
Thanks a lot in advance for your help.
tirza.ben-ner
Hi @giuseppina.broggiBE,
AutoCAD 360 is the official AutoCAD mobile app.
AutoCAD 360 is an easy-to-use drawing and drafting mobile app that allows you to view, create, edit, and share AutoCAD drawings - anytime, anywhere. Simplify your site visits and field work with powerful design review and markup tools - available online and offline. Upload and open 2D DWG drawings directly from email and view all aspects of your DWG file, including external references, layers, and image underlays. Upgrade to AutoCAD 360 Pro to further expand functionality. Design every detail, everywhere.
For more info visit our website- http://www.autodesk.com/products/autocad-360/overview
Feel free to contact us with any further question.
Tirza Ben-Ner
AutoCAD 360 Support Specialist
