I'm a newb using Autocad on my iPad to do some as built drawings. I can add dimensions to a drawing which is easy enough but as the dimension text is not right because it's an asbuilt I want to be able to edit the dimension text, kind of override it as you can on full Autocad on a PC. Is this possible on Autocad for iPad?
TIA
olly
Solved by john.vellek. Go to Solution.
i don't know what AutoCAD features are used on ipad , but have you try Edit dim tool or Ctrl+1 properties dialog .
Hi @Anonymous,
The dimensions are going to be connected to the geometry and cannot be "edited" like you can in the desktop versions. You can obviously modify the geometry to get the dimension to display the correct field measurement but I find it is easier too just add a piece of annotation with the field measurement.
Hi @Anonymous,
I am checking back to see if my post helped you with your problem or question. Please mark a post or posts as accepted solutions if they resolved the issue or give me a bit more detail on this issue so we can continue to work towards getting this solved.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
Autocad app doesn’t work with commands unfortunately,,,,I m looking for if it can be possible, for now only a ‘’’’few” “tools”,,,,not editable,,,,,so sod for AUTODESK - AUTOCAD APP
@imadHabash wrote:Hi,
When we draw a line with a dimension 250 and we want to change it to 255, there is no option to change the dimension.
