Hye Everyone,
Is the any Autocad Or 3D DWG can use on all android with any version of android or iphone...
Solved by john.vellek. Go to Solution.
Solved by pendean. Go to Solution.
Hi @Anonymous,
Here is a link to the app on Google Play. Here is a link to the Apple Store.
There is also a Community forum dedicated to AutoCAD Mobile where you can view and ask additional questions regarding this application.
thanks...i think miss understanding little bit my question...latest version of such ios or android latest version...such as latest gadget should be no problem...
i mean if in education...such lower version mobile before for student also can do some study about autocad...like we adult may can afford the software...sorry if ask this for discussion...just thinking about next generation...that will become much advance than me...hehehe... thanks
The latest version of ios or android are bale to support the AutoCad ,Any phone device supports compatibility, no matter you are going to use it on your Android or iPhone , you can even switch it from Android to iPhone ,
@Anonymous wrote:The latest version of ios or android are bale to support the AutoCad ,Any phone device supports compatibility, no matter you are going to use it on your Android or iPhone , you can even move it from Android to iPhone ,
Thanks , i get it , we can move between iPhone and Android
@Anonymouswrote:If you want to do what i said , you'd better via USB cable , Because the Wifi doesn't have the power to help you.
Here's a tutorial you can look at.
Sure , it is possible ,
Can u say something about a mobile-spy-apps.com mobile recorder on Android? How does it work with other applications?
