Warning: an error occurred during save
Berrys_Cooling_Drafter
can someone help me why this is happening when I save my file and how do I avoid this to happen again and how do  Iauto cad message.JPG run a recover
Tiana_Y
Hi @Berrys_Cooling_Drafter
That message is a prompt to let you know that your files might be corrupted. It could be due to several different things within the file that have become corrupted. I would try the following steps in the attached AKN article, To Repair Corrupt AutoCAD FilesYou can also use the RECOVER command to fix the file. Hope this helps!
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Tiana.D
Community Program Manager
Contact Autodesk Support
Tiana_Y
I'm just checking in to see if you need more help with this. Did the suggestion I provided work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Tiana.D
