Good Afternoon All,
I have recieved a file from an Architect who had used Wall Command (objects)
I've tried to edit object displays, i've scoured the internet and now I am here due to no luck discovering a fix. How do I turn these off without exploding the object?
These symbols are also plotting as well.
Solved by Gepaha. Go to Solution.
I've attached the file that has the issue, in case anyone wanted to delve into it. Thanks In Advance.
Thanks a bunch! I can't believe I've never ran into something like this before.
