AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
Unreconciled new layers
3 REPLIES 3
10176 Views, 3 Replies
Hi, anyone know how fix the message unreconciled new layers in mep 2009, its quiet annoying evrytime specially when I am doing plotting.
3 REPLIES 3
command is LAYEREVAL, set to zero....only way i know is to do each dwg, not a global command
it works, thanks a lot..
michaelrouse4488
hello,
Just thought I'd put my two cents in... I believe there is a universal way of removing unreconciled layers. I think you go under layer manager and then go to settings... Turn off evaluate new layers check box. that should do it. Not sure if it carries over projects but you shouldnt have to worry about it when in that particular project again.
Hope it works,
mike
