AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
tool pallet group not changing from plumbing
5 REPLIES 5
ashreid20
476 Views, 5 Replies
I am having an issue with the tool pallet group not changing away from 'plumbing'.
When trying to do electrical work this is becoming really tiresome. I have reinstalled the application but to no effect.
I hope the pictures illustrates the issue:
any help is appreciated.
Tags (2)
5 REPLIES 5
Eng-Seng
in reply to: ashreid20
you may want to try workspace switching to show the correct tools in the ribbon and tool palette.
https://help.autodesk.com/view/BLDSYS/2024/ENU/?guid=GUID-35AC471A-5B2C-4E05-BFB6-867B0CD937E1
regards,
Eng Seng.Chua
AutoCAD Toolsets
ashreid20
in reply to: Eng-Seng
If you look at my pictures, you will see that I have done that with no effect.
pendean
No, what you show in your screenshots is something that has never worked like that in any earlier version AFAIK. It can also be done it this way (see below) if you don't use Workspaces
Eng-Seng
From your screenshot, it seems like you might have switched to "Electrical" display configuration instead.
please check if you are really in Electrical workspace (using the Gear icon at the bottom right).
Eng Seng.Chua
AutoCAD Toolsets
ashreid20
faceparm moment for me that one.
cheers
