tool palette
tool palette
Berrys_Cooling_Drafter
tool palette
unable to drag anything from my model space to the tool palettes
J__A
First open up the palettes, in the commandline type toolpalettes.
Once there rightclick in the window to get the alts up, then create a new one or add commands.
I added an pic if its easier to understand,
Best regards / A
PALETTEPALETTE
I think you did not understand my question I will explain
there is such a thing as making your own tool pallet tab and adding blocks and tags to it then wh you want to use in your drawing you just drag it in I know there is a way to add stuff to you're by dragging items from you're drawing into the palette it doesn't work do you know why or whats an alternative way to put stuff from my drawing into the tool palette
J__A
Okay i will try one more time.
Did u try with designcenter? Is it at the part where you pull them out that you cant insert them into the palette?
 If its just 1 or 2 blocks you want to preset you can also add in the command string what block to insert and ratio n scale etc.
no, I want to put like dimension or an elevation tag or a radius tag or a block that I have in my drawing I want to put it to the palette to be able to use it again do you understand it's not anywhere else only in my drawing I want it in my tool palette
J__A
Sry then idk how to solve that problem, if its predefined i recommend you to look around in designcenter.
