Hi all,
I'm in the process of setting up a new profile and cui for my MEP group, everything else works however the tool palette groups are not persistent. After setting up the palettes, then exporting the current profile, I attempt to load that profile on my co-workers ACAD. However the tool palette groups are gone. I then attempt to delete and import the profile to my ACAD and the same thing happens, the groups are gone and all our various workspaces change to "All Palettes".
I can import the .xpg file and the groups appear, and function between our various workspaces. However, after a profile re-load the same thing happens, they disappear.
I have checked, double checked, and triple checked my "Options>Files>Tool Palette... Path" and its path-ed to a folder with all the .xtp, xpg, and .atc files.
I have done a lot of internet searching with no solutions found.
Note: our previous 2014 profile had very similar tool palette groups setup and they function correctly...
Looking for advice and suggestions on things to check. I do not need replies about the superiority of "design center" or alike, our workflow utilizes tool palettes more effectively then the design center.
